Hi R3V I was driving my e30 last night back from the socal meet and it drove fine until about 3/4 of a mile after I exit the freeway. I was just in 2nd (auto) and was doing about 50 when i felt suden loss of power. It did completely nothing even when I went 100% throttle with the kick down it felt like as if the car was off. I pulled over and let it roll in drive and all ot did was just bog and idle like crap. When j pressed the gas while rolling at about 5mph it bogged even more and turned on the MIL (CEL). i just had it rolling for about 7 minutes and it did climb a little uphill part at about 5mph and then all of a sudden power came back and it started to run fine until i messed with it again and put it to the floor. It felt as if i was out of has but i have 3/4 of 91 in the tank. I got home to do the stomp test and i got 1222.
I know that 1222 means cars either operating rich on lean. I am sure its lean because it feels as if i need fas but i have gas. It drove fine today morning to work.
The parts that can cause this are:
O2 sensor
Afm
Vaccum leak
Fuel filter (new)
Icv? (New)
Tps?
Temp switch (new)
Fuel pump
Sparkplugs (new)
Wires (new)
Cap and rotor?
Or faulty injectors?
My econometer doesnt work but I have measured and approximately I get about 8mpg city and 13mpg highway
Car has about 183xxx miles on i it and has never done this before.
Note: my friend borrowed my car and scraped the exhaust and there is a hole after the cat past the flanges. Car also has a new alternator battery and all fuses look fine.
I will do a smoke test today and keep you guys informed. Any help would be appreciated. Thank you
O2 sensor
Afm
Vaccum leak
Fuel filter (new)
Icv? (New)
Tps?
Temp switch (new)
Fuel pump
Sparkplugs (new)
Wires (new)
Cap and rotor?
