idle surge and constant miss
  • jamorrow36
    • Jan 2015
    • 7
    89 325i 5 speed, car starts and imidiately starts surging until you Rev it up a couple times then it rests at idle and throttle response us good but there's a constant mis through the rpm range. When the car gets up to temp throttle response gets shitty and slow
    Parts replaced/checked
    Head resurfaced,new gasket
    All vacume lines that were rotted were replaced, then used rtv to seal connections,
    Checked cps
    Swapped dme
    New plugs, wires, good coil
    Good injectors, good fpr, fuel filter
    Put a good working am on it and it wouldn't stop surging?
    Iac valve buzzing as it should
    Checked for vacume leaks
    Checked for exauhst leaks
    Replaced o2 sensor
    Replaced coolant temp sensor
    Relaced valve cover gasket
    There's probably more things I've done that I'm just forgetting but nothing I have already done has made it better. If anybody has had this problem and fixed it it would be greatly appreciated if you could let me know the secret fix.
  • ahlem
    • 369
    Get a spark tester and check the coil output and at each plug to be sure it's not an ignition issue.
    Surging is typical of a lean-out condition usually caused by a vacuum leak or due to some faulty sensor input.
    Sensor inputs can be affected by the wiring and plugs attached to the sensors as well as a sensor. In your case, you might be best off to systematically unplug sensors to see if you have any effect. If you have a buddy with the same car, you can both unplug the same sensor and see what the difference is.
    Just for yucks and grins, I'd start with the wires to the coolant temp sensor.
    Your CPS will be tested indirectly via the spark tester.
    • goldenbb
      • Jun 2013
      • 208
      Did you open the airflow meter and check that the wiper arm is making good contact with the surface it rides on? If it isn't, it's the same thing as unplugging the afm completely.
      '90 zinno 325iS
