325ix M20 Fuel Pump
  • boogle2
    • Dec 2014
    • 115
    325ix M20 Fuel Pump
    I'm unsure if the behavior of my car is appropriate. When I turn the key to the "on" position without starting, I can hear the fuel pump quite loudly, and it stays on for as long as the key is in the 'on' position. My question is:
    1: is it normal for the pump to be loud enough to be heard?
    2. should the pump run always, or should it turn on for a few seconds and then off?
    I just did a fuel pressure test last night and got 43psi at idle and 49 psi with the FPR disconnected.
    2011 335i xDrive Msport - sold
    2002 M5
    '88 325ix turbo build :D
  • dnguyen1963
    • Nov 2011
    • 2649
    When you turn the key to "on", the fuel pump should run for only a few seconds. No, the pump should be quiet. If you can hear it loudly then it is on its way out.
    • boogle2
      • Dec 2014
      • 115
      Thanks for the reply. Any idea what would cause the pump to stay on? Could it be a grounding issue?
      2002 M5
        On an E30, the pump should only run when the DME sees timing data from a rotating engine. Sounds like someone has done some "creative" mods to the fuel pump wiring.
        As dnguyen1963 said, The pump should be quiet.
