Starting the engine
  • Hussbuss
    • Feb 2015
    • 25
    Starting the engine
    So every day I go to start my car, I hear the starter running but the engine doesn't turn over/run. So I try to start it again, and usually after the 2nd or 3rd time it'll then turn over. This has happened for a while now and I'm not quite sure what it could be. Thoughts?
    Schwartz '84 325e
  • george graves
    • 20003
    Starter solenoid. It's not a replaceable part. Buy a reman BOSCH starter(don't waist your money on anything else). I got mine off of ebay from some hole in the wall place that does nothing but rebuild starter. But I think you can get a reman from autozone now-a-days.
    Most likely the problem will get worse. If you get stuck, hit the starter with something heavy - that will loosen it up (but if you ding it up, they may not accept it as a core)
    Originally posted by Matt-B
    • Hussbuss
      • Feb 2015
      • 25
      Checked ebay, all they have are starters for the 2.5, not the 2.7.. Autozone has a Duralast for the 2.7.. any other suggestions?
      Schwartz '84 325e
      • george graves
        • 20003
        Here's the guy I used: http://stores.ebay.com/eagleautoelectric/ - good work - no problems over a year later. But it's literally a hole in the wall kind of place - but that's all he does - so I have to assume he knows his stuff.
        I'd wait a bit - I'm sure someone else will chime in with more sources to choose from.
