Hey guys
So I had my car apart for a while and then buttoned everything up about a year ago and it ran fine. I then left the state for a while and upon coming back I am having a no start issue
Fuel pump works (verified by jumping straight to batter)
Started looking at the wiring
referenced this: http://www.r3vlimited.com/board/show...21&postcount=9
also referenced this diagram: http://www.r3vlimited.com/board/atta...1&d=1295932597
when i jumped from 30 to 87 The pump does not run. i can also hear the fp relay clicking when I start the car with the fp relay in place. So the relay appears okay When I jump from socket 30 on (fp relay) to fuse 11 then the pump runs. So, the wiring from the fuse back to the pump is good.
I seem to have a problem between the output from the fp relay and fuse box
this is where I am confused. the diagram says the wire coming from socket 87 should be green and violet and go to the c101 connector. however the wire is blue and green and goes to the ecu. the green violet wire on the c101 connector (pin 13) also seems to go to the ecu.. do I have a bad ecu? I dont have another to swap and test... Could it be a wiring problem at the ecu connection. Why does the diagram not show the wiring going through the ecu?
I am getting stumped here and I had planned to drive my car cross country and now things are getting hectic. ANy help is appreciated.... is there something i am missing?
