Hi guys i need your help. We did a timing belt,water pump,camshaft seal and oring,thermostat on my friends car and now it cranks but wont start. First i thought i did the timing wrong and bent valves. But no double checked timing and its right. All tdc marks line up.the belt is on firm and everything is connected. Except for radiator and hoses. I am getting yellowish spark and the injectors should be firing if all cylinder are flooding and weting the plugs.
Pulled plugs and dried them with compressed air. Double checked spark still have it. Put the plugs back in still doesnt turn over. Pulled them out they are wet again.
I have a crank position sensor on the way now. But it will be delivered to me in 8 hours. So any help would be greatly apriciated.
Btw the rotor and cap are fairly new the rotor has lots of life left on it and the cap has minor carbon but i sanded those with 2000 grit sand paper twich over each of the prong things.
Could have we disconnected something or banged the crank position sensor?
1989 E30 325i Sedan Alpine
