Hey guys so I'm doing a valve adjustment and valve cover gasket replacement. I was wondering what material head gasket would work better? Should I go with a molded rubber? Or a composite?
M20 valve cover gasket
Tags: None
I was getting the VR gaskets which are composite with a bead of rubbery stuff in the middle, but they were so stiff they wouldn't seal. I ended up using RTV on it and that solved it. As such, I'd say try the softer rubber gasket.Interested in vintage cars? Ever thought about racing one? Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
Elva Courier build thread here! -
Goetze makes the best valve cover gasket imo. I've had Elring and VR leak, but after installing a Goetze gasket things have been bone dry.Comment
Many leak after replacement because people don't replace the rubber rocker end plugs, be sure to replace them.Comment
the felpro gaskets are actually pretty nice, silicone beads on a fiber material over a steel core. also $20 and in stock at my local advance auto partsComment
