So, my kids and I are about 4 weeks into restoring a 1990 325i. We started with brakes. Today we completed rebuilding all the calipers and attaching everything back on the car including new brake hoses.
When we started bleeding the brakes I heard air coming from the engine compartment when my son pressed the brake pedal. After bleeding the brakes they seemed to work fine. I took it on a 10 minute test ride and gave the brakes a good test. However, I don't know how "strong" the power assist is supposed to feel since I've never driven another e30. It certainly doesn't brake like my 2009 BMW.
So, my concern is that the vacuum booster could be toast. However, when I press and hold the pedal it seems to hold pressure although I must admit that I don't know exacting how much it would move over 15-20 seconds if it was leaking. So, my question is - anything else that would leak air around the master cylinder / vacuum booster that could be heard when pressing the brake pedal?
I haven't started testing check valves yet but wanted to post this question to see what sort of help I could get.
Thanks!
Thanks!
