I swapped those sensors with brand new ones already. I disconnected the old ones to check ohms and the connectors just crumbled.
85 Eta, Fuel but no spark
Yeah. Tested and have power at 18 and 35 even with ignition off, donno if that's normal. Have starter power during start. Have continuity between the spark output of the ecu and the coil. Also checked all grounds. Check fuel injectors and fuel pump. All electronics check outComment
You made me get outta bed for that one. A quick bench test and it does indeed switch outputs. 87Q (which is how its designated on my relay) is on when the coil is not active. Once the coil becomes active, 87Q shuts off and 87 turns on. Ignition off and I get power to the ECU, ignition on and I don't get power. We may have figured this one out. I'll be up before dawn to grab a new main relay and have this running good and well by the morning.Comment
Well the car starts now. It runs pretty poorly, but it's what you can expect from a car that hasn't run in 10 years. For anyone troubleshooting and reading this, do check your main relay and make sure it's not 87, 87a and that it is 87, 87. Thanks so much RobDogComment
