Where is the EVAP purge valve located?
    Basically what the title says. My CEL turned on and the code is 1263 which is the purge valve. My idle is kinda dick-y when it's cold so I want to check out the valve but can't find it.
    Under the intake manifold, follow the left line from the charcoal canister (Black 4" (ish) diameter cylinder under the brake booster) and that'll lead you to it. The purge valve has an electrical connector that may need cleaning and a shot of dielectric grease.
      Found it, thanks!
