No spark or fuel injector pulse
  • Downshift-E30
    • Nov 2015
    • 88
    Car is an 87 325e, fuel pump runs when cranking.
    Car has the flywheel for a jetronic e30 but with timing tab welded onto it.
    Checked crank reference sensor for ohms and Ac voltage
    2 ecus
    2 wiring harnesses due to first one being bad
    All fuses good
    Tab on flywheel still good. Plz help before I swap flywheel for stock
    R&M Performance Auto Care
    Daily: 03' 530i
    Project: 87' 325e race/track car
    BMW Gearhead/Tech
  • peterman
    • Feb 2015
    • 177
    Did you try the Main relay?
    What were the ohms on the CPS? should be 500-540ish (pins 1 and 2).
    Did you flip the connectors to where the CPS and the plug wires under the intake manifold? This will give that problem although I think the fuel pump wont run while cranking if you did.
    Edit: Did it ever run? or are you trying to get it started for the first time.
    • Downshift-E30
      • Nov 2015
      • 88
      Yes for the first time trying to run and I believe it's supposed to be 960 with the bell housing sensor. I have flipped them but the grey connector marks the sensors
      Daily: 03' 530i
      BMW Gearhead/Tech
      • peterman
        • Feb 2015
        • 177
        Not talking about the bell housing sensor. CPS and spark plug wire pulse wire in the front of the engine.
        How do you know there's no pulse? Did you put a stethoscope on the injector?
        Also, the fuel return should be connected to the FPR on the fuel rail.
        • Downshift-E30
          • Nov 2015
          • 88
          I have the cps that is mounted on bell housing. There is no sensor on the front of the crank. And I felt for it and no click at all. Gets fuel to the rail just the injectors are not being operated
          Daily: 03' 530i
          BMW Gearhead/Tech
          • peterman
            • Feb 2015
            • 177
            automatic? could be the neutral safety switch.
            • Downshift-E30
              • Nov 2015
              • 88
              5sp. I'm gonna check by switching the sensors tonight and checking pin outs on ecu one more time. Ecu should be getting power if fuel pump is running correct?
              Daily: 03' 530i
              BMW Gearhead/Tech
              • peterman
                • Feb 2015
                • 177
                I believe fuel pump is always hot in the crank position but I'm not sure. do you get 12V at the coil in run position? The green striped wire to body ground, not across coil.
                • Downshift-E30
                  • Nov 2015
                  • 88
                  Yes I do. I will double check today since this one is new engine harness
                  Daily: 03' 530i
                  BMW Gearhead/Tech
                  • peterman
                    • Feb 2015
                    • 177
                    Then the spark problem is forward of the coil, ie cap, rotor, wires, plugs.
                    The CPS should only turn off injector pulse, not spark - I think, not sure if this is true about the bell housing sensor.
                    What about the main relay?
                    • Downshift-E30
                      • Nov 2015
                      • 88
                      It controls spark as well. I checked spark at the lead coil wire which eliminates cap rotor and all that. Wire Is good too
                      Daily: 03' 530i
                      BMW Gearhead/Tech
                      • Downshift-E30
                        • Nov 2015
                        • 88
                        Main relay I tried between 3 different ones and same thing
                        Daily: 03' 530i
                        BMW Gearhead/Tech
                        • peterman
                          • Feb 2015
                          • 177
                          New flywheel on backwards? Ie. not in line with the bell housing sensor
                          • RobDog
                            • Aug 2012
                            • 188
                            Is your main relay a double pin 87 and not a 87, 87A. The main relay should power 2 pins (87,87) and not switch power between pins (87,87a). Also does your car have a 13 button OBC. If so there is a chance that the OBC code function is preventing your car from starting. The OBC code function kills spark and injector pulse.
                            Here is a link that might help with what I suggested above.
                            • Downshift-E30
                              • Nov 2015
                              • 88
                              Oh thank you! I will check I have a feeling that might be part of it but I'll let you guys know tonifhr
                              Daily: 03' 530i
                              BMW Gearhead/Tech
