1987 m20B27 5spd
Hit and miss idle...
While cruising chocked and died.
Limped back home at barely an idle.
Went over the usual suspects...
Maf
Tps
Icv
Cps
Coolant temp sensor
Fuel pump
Main relay
Fuel pump relay
Coil.
Cold start valve
Checked for fuel in tank
It'll fire up idle for 3-5 seconds and die no matter how much throttle is given.
Found abundance of fuel in intake boot to maf and even into tps.
Wtf is going on???
Maf
Tps
Icv
Cps
Coolant temp sensor
Fuel pump
Main relay
Fuel pump relay
Coil.
Cold start valve
Wtf is going on???
