Did more searching and have a simmilar querstion to the motor mount blots. Do you all reuse thme, or replace them???
Guibo/Flex disk bolts
I reused mine after cleaning them up and making sure the threads were good on everything. Honestly, it's not like flywheel bolts where you need new thread locker, so I'd say they are good to go if not damaged.The fun never ends :-?
89 318iS
R.I.P 89 325i coupe
89 335iC -
I've always reused them, however I've also lost two. Soo.. If you're in a hurry just clean them and locktite. Otherwise replace is never a bad optionF80 M3 Alpine
E10 Fjord Blue 2002
E28 Blackish 535i
E21 Silver 320i
Disco1 98 4.6
E30 Cirrus coupe S50 SOLD
E30 325i SOLD
E30 Alpine 325i vert Euro spec SOLD
E30 Alpine coupe 325is SOLD
sigpicComment
Well, I did this this weekend. The bently says you have to use new nuts because they Are locking nuts. Felt like they were. I had to remove the entire exhaust. It took me all day. I was in no rush and took my time. But I'll leave this open to other questions.Last edited by rcsoundn1; 04-10-2016, 05:54 AM.Comment
The head of those nuts are swaged to create an interference thread fit, once they are used the interference effect is lessened so strictly speaking they should be replaced.
Blue threadlock should work okay but they are in such an awkward place they warrant replacement.Comment
