Hey all, long time lurker and new e30 owner as of 2 months ago. Ive already taken care of some maintenance items so I can drive the car worry free(ish).
I recently replaced the intake boot and some other vacuum hoses trying to eliminate a vacuum leak some where. This definitely helped remove some of the hesitation that I was feeling between 1500-2000rpms.
The car still seems to hesitate in that rpm range. When I bought the car I simply overlooked the o2 sensor and then looking for remedies for the possible hesitation issue, I found the o2 sensor wires cut, and tucked in/hiding! The clip that it would connect to under the battery tray is gone and i see no other wires leading to the DME (other than the main leading to the harness).
I would like to get the o2 sensor hooked up properly, but I can't find how the o2 sensor should be hooked up. I have some other suspect looking wires coming from the main harness. One of them is running into fuse relay #9?!?
Thank you for the help
