Large idle surge when pressing the accelerator when cold
    So I got this weird idle going on and am unsure what is the cause of it. Once the car is started up in the morning, if you hold the accelerator to about 1k the idle will rev up to about 1.5k on its own and bounce between 1k and 1.5k while you are trying to maintain 1k. I hope that is fairly clear. Please ask if I need to clarify more.
    The car has been smoked tested and no vacuum leaks were found.
    The TPS passes the continuity check.
    I've swapped ECU's to see if that is faulty. I have a SSSquid chip but I don't think that could be a culprit as it wasn't when I got it.
    I have replaced the cold temp sensor.
    I have replaced the spark plugs.
    Idk what could cause this anomaly. This only occurs if the car hasn't warmed up cause if you try to drive when its cold it feels restricted until it warms up then its like a whole new car so this large surge when pressing the accelerator seems to be underlying culprit.
    Any help would be appreciated.
    1986 325
    1988 325is 2.7 Stroker
    Try to adjust the TPS. It may be telling your ecu it's open. See the write up in the Bentley manual.
