Ran AC in heavy traffic; car sputtered and then wouldn't start
  • Maggiolone
    • Oct 2015
    • 56
    I was in heavy traffic with a load of passengers and luggage in my 325e. The car began to sputter and shake; the oil warning light would flicker and the temp gauge creeped slowly to the red.
    We got to our destination without over-heating. I attempted to start the car a minute later, and I received NOTHING when I turned the key. I initially thought it was a dead battery.
    3 hours later, the car started and ran fine - without the AC on, too.
    I don't know. ICM? ICV? Or, new battery needed?
  • getouth
    • Jan 2010
    • 3343
    sounds like an electrical relay issue ....... gets too hot and doesn't work right, cools off and is GTG.
    FEEDBACK:
    http://www.r3vlimited.com/board/showthread.php?t=316212
    BMWCCA #398608
    IG @yagayo38
    "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
    • Das Delfin
      • Sep 2014
      • 2293
      CPS possibly.. it's not unheard of
      check your oil first
      • mazzo
        • Jul 2014
        • 264
        Any check engine light on?
        Current:
        '88 325ic Silver 5sp
        '17 Subaru Outback 3.6R
        Past:
        '14 Rav4 EV (with tons of torque!)
        '06 325i Black 5sp
        '02 S4 Avant Black 6sp
        '00 Boxster Silver 5sp
        '98 New Bettle Yellow 5sp
        • george graves
          • 20003
          My guess - it's unrelated to the AC in traffic (and who in the world still has AC in their e30?!?!?!? - ok, that's not far, if live in a hot part of the country, I would love AC
          Check the voltage while the engine is off, and then when running.
          Engine off should be ~12 volts
          Engine running should be above 13 volt
          Originally posted by Matt-B
          • Maggiolone
            • Oct 2015
            • 56
            I took it upon myself to get a new coolant temp sensor and thermostat. Those helped a bit.
            I can safely drive with myself and the AC on. I had passengers again, and my shotgun passenger put the blower motor up to the highest setting. The car stalled. I immediately restarted it, with the fan low.
            I'm going to buy a new battery today. The alternator is newer.
            • DesertBMW
              • Aug 2011
              • 1043
              Engine overheated so much that pistons expanded and were locking up against the block. After you shut it off, there was too much friction for starter to move the pistons. But when engine cooled off, pistons shrank and you were able to start it again. Cylinder walls are scratched now.
