Had a heck of a time figuring out where this oil leak is coming from. I have replaced the head gasket, camshaft seal and o-ring, valve cover gasket and seals, and oil pan gasket but the passenger side of the engine is still soaked with oil. The oil filter is soaked. I checked to make sure the filter wasn't double sealed and that it was on tight. You guys think it's the oil filter housing seals? I just wouldn't think they would cause a leak this bad.
Thanks
Thanks
