325e Lateral Fuel Filter
  • Rojoryu
    • Jul 2016
    • 58
    I'm sure I'll get flamed, but I've learned to always make sure of something even if it seems obvious. Here goes...
    Recently picked up my first e30, a 1986 es. I noticed a looping idle and it did not have the low end torque that these motors are known for. In fact it doesnt do much until about 3k all the way to 5.3k (must have a chip already). So I checked plugs, ICV, AFM, then I noticed fuel pooling on top of the fuel filter (this model has a lateral filter in the engine bay). I also notice that the direction arrow was point down (line toward the tank) instead of up to the fuel rail. I can only assume this is incorrect and the cause of my issues?
    Can I just replace with the correct filter from a big box store (Autozone)?
    Thanks in advance.
  • efficient
    • Feb 2012
    • 3312
    You need to flip the fuel filter. The arrow is supposed to go towards the motor pointing up. You can replace with a fuel filter from autozone just try to get one that fits the bracket so it's not just dangling around
    • Rojoryu
      • Jul 2016
      • 58
      Thanks for the help! I'll get a new one. Could that have been causing the issues?
