M20 injector Q. Beige top 325e
  • BFT_Boyle
    • Jul 2016
    • 199
    Hey gang,
    I'm going through my injectors right now and was wondering how the out going spray should look on a "clean" injector. Right now I just have a squeeze bottle of IPA going into the inlet port. Applying power gives me a steady even stream. Nothing like a mist/spray ( likely due to low pressure)
    I know this isn't the ideal setup and the actual fuel pressure is more than my squeeze bottle, but would you say this suffices for and adequate "clean"? I'm mostly verifying they work before I install. Ill be running a fuel system cleaner once I get everything fired up.
    Thanks!
    Sent from my XT1585 using Tapatalk
  • BFT_Boyle
    • Jul 2016
    • 199
    Figured it out...Ended up applying some compressed air behind the IPA. Sprays nicely.
