Diagnosing hard warm start
  • berndt
    • Mar 2016
    • 104
    Sorry, I haven't replied earlier. I haven't had a chance to work on the car until today. Anyway, I decided to replace the injectors. I bought some refurbished ones on eBay. I won't know for an hour or so, if the fix worked, but based on what the injectors looked like, I'm glad I replaced them regardless.
    • berndt
      • Mar 2016
      • 104
      Now I have a oil level light on :(. I'm guessing I jostled the connector.
      • berndt
        • Mar 2016
        • 104
        Well, the car runs awesome (a little better than before), but the hard start is still present. At this point, I'm guessing FPR or fuel pump, since I'm not leaking fuel anywhere.
        • mrsleeve
          • Mar 2005
          • 16390
          Try cycling the key 2-3 times when warm, to get a good prime on the fuel system and see if that helps...... Is your coolant level staying where it should be.
          Originally posted by Fusion
          William Pitt-
          • berndt
            • Mar 2016
            • 104
            It pretty much always starts and runs fine after second crank when warm. Fuel pump doesn't prime in these cars from what I've read. Won't start till cranking.
            • berndt
              • Mar 2016
              • 104
              Coolant level seems fine. No leaks.
              • IS300E30
                • Apr 2009
                • 408
                Was this ever resolved, I am having the same issue.
                I just cannot figure out a solution, no matter how many parts I throw at it.
