Hey guys never introduced myself and my 1988 325i cab. Currently limping around and idk why it surges and bucks under load and now stalls sometomes when coming from a stop. i have so far cleaned the injectors and rail new fuel filter and relatively new fuel pump new plugs and timing redone i think theres rust in the tank but that shouldnt hurt too much right could i just flush it? Also how can i check fuel pressure? Its an m20b25. Also i cut off the cat because i thought it was clogged lol so thats not it
M20 surging and stalling under load
When a reporter asked, "How did it feel to fail 1,000 times?" Edison replied, "I didn’t fail 1,000 times. The light bulb was an invention with 1,000 steps."Tags: None -
Please use the search function here. There are countless suggestions for this problem. First thing that comes to mind is intake leak. Have a shop perform a smoke test on your car. -
I have searched all over and no one seems to have what i have going on or if they have its not solved i have checked vaccuum and intake leaks and nothing so farWhen a reporter asked, "How did it feel to fail 1,000 times?" Edison replied, "I didn’t fail 1,000 times. The light bulb was an invention with 1,000 steps."Comment
The only reliable test for intake leaks is a smoke test with a pro machine. Intake leaks may be part of the problem, but I suspect there is more going on. But start withe a properly executed smoke test.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
