Anyone have an M20 that idles perfectly with no audible misfire?
  • staysideways
    • Dec 2013
    • 373
    Both my 88 and 89 have the stumble at idle. It's like hmmmmmmmmmmmmmmmmmmm--mmmmmmmmm-mmmmmm it's very common but if you find a fix for it please post.
    • IceWhite
      • Jan 2015
      • 945
      Check out this thread. How should an M20 idle anyway?
      1990 325i
      2004 330i Individual 6-speed
      • PKile
        • Apr 2016
        • 184
        Great thread! Nice to know we are not alone with this problem.
        There's one other thing I'm goinng to try...there may be an issue with the upper o-ring on my bitch tube. I got a slight idle speed jump when I was dousing my throttle body hose connections with carb cleaner, but only near the bottom. When I replaced the o-rings during the rebuild, I may have gotten a used o-ring in the top position. I think I can R&R the upper o-ring by pushing the tube down (not possible with the lower o-ring). That bitch tube is one of the more irritating design features of the M20, almost as awful as the pushrod tubes on an air cooled VW...
        • salvageland
          • Aug 2016
          • 149
          Before you tear into the tight quarters of the bitch tube. You can rule out leaks around the bitch tube, valve cover gasket, oil dipstick by bypassing the hose that runs from valve cover to TB and see if you hear any improvement.
          My 93' vert has same issue. Rebuilt motor, changed all sensors, ignition system, seals, which improved things quite a bit and it runs amazingly strong, but still have the intermittent miss during warm idle.
