ABS and clutch pedal question
  • Supratreo
    • Aug 2016
    • 135
    hi, so were getting closer to completing the b25/260 swap on our 87 ETA but had 2 quick questions.
    1) i modified our new 89 harness by cutting wire 20 assuming we don't have ABS because pin 20 in the engine bay harness is a brown wire which i thought was ground (meaning no ABS?). later i realized we might have abs because the car has what looks like a abs actuator/pump. any thoughts?
    2) we got the pedal assy. from the wreckers and i thought we got EVERY part that was associated with it but i THINK i might be missing 1 spring.
    http://www.realoem.com/bmw/enUS/show...diagId=35_0183
    it is #22 on that diagram, compression spring for clutch pedal. i know if i saw it on the car i would have brought it home with me, are these on all manual cars? if so, i need to find one.
    thank you
