I installed an MTXL wideband O2 gauge on my head swapped 325e using the existing stock 02 relay; power is from the relay, and the output goes to the Ecuador through a cut and spliced stock o2 connector.
The issue I have is it seems power from the relay gets cut in certain circumstances (I believe I read it was 3k rpm and wide open throttle but kcojldnt find the reference where I read that); is there a good way to modify the stock wiring to stop the power from shutting off? Or a better way to wire this that I've overlooked?
