I've been hesitant to post my issue because I thought I would try everything before I would ask for help.
1990 325iX manual transmission 190k miles-If the throttle is pressed lightly at idle the rpm's will dip and then surge back up to idle. More prevalent when engine is cold. Engine runs all the way up to redline and pulls hard otherwise.
Heres everything that I have tried to do to remedy the problem:
Smoke checked the vehicle 3!!!! times. I connected the smoke machine to the small vacuum line that goes to the intake manifold, pulled off of the fuel pressure regulator.
Tried 2 different AFMs. No difference. I have even tried to refurb one recently (after I tested both last year) by elongating the holes on the circuit board to move the wiper onto a fresh track. No change. I even tried to enrichen the mixture by adjusting the spring tension. No change. Adjusted the idle mixture as well. Now I'm back to my untouched AFM.
Tried 3 different idle control motors. Before and after cleaning them with carb cleaner..no change.
Brand New fuel pump, tank, LINES, filter..tank to fuel rail.
All throttle body connections are secure..JB welded one of the loose connections 4 years ago when I first bought the vehicle.
Tested fuel pressure and volume twice, all within specs.
Replaced Coolant temp sensor.
Coil, wires, distributor cap, rotor, plugs ALL brand new.
Tried several crank position sensors.
Crankcase hose is brand new, intake boot is brand new, took intake manifold off and replaced gaskets, and throttle body gasket. Oil return pipe orings as well.
Valve adjustment done twice..second time just to confirm within specs.
Timing belt just done...and rechecked to make sure timing is spot on.
Checked oxygen sensor for cycling output with snap on oscilloscope. Checked good.
Re wired C191 plug under intake with GM weatherpack connectors. Fabricated 2 6 gauge grounds from battery cables from engine to frame. Did all Bentley DME wire tests at DME connector in glove box.
Fuel injectors are brand new...newer style revised nozzles.
Brand new TPS adjuster to spec per Bentley.
I am at a loss at this point, it sucks taking off while the engine is cold..hitting the gas just right will make the sputter and chug.
Not sure what else it could be at this point..i'm considering just going megasquirt to try and remedy this problem..
Idle has alway been a little stumbly no matter what part I have thrown at it BUT is just like any other M20 I have owned.
Any suggestions?
Any suggestions?
