Sudden surging
  • mjposner
    • Aug 2015
    • 169
    Sudden surging
    Thursday I replaced air filter and spark plugs, drove 50 miles on friday, no issues. This a.m. I go to drive and I am getting a small 200 rpm idle surge. No loose hoses, any ideas?
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5575
    You may have cracked the intake boot while taking off the filter. Get some brake cleaner and spray around the intake to see if a vacuum leak is the cause.
    • mjposner
      • Aug 2015
      • 169
      good thought, it was very stiff and hard to reattach.
      • mjposner
        • Aug 2015
        • 169
        Also, no clamp between intake tube and suction tube.
        • mjposner
          • Aug 2015
          • 169
          Took air box out and then added a rubber boot/clamp between suction tube and intake boot. Still seems to surge 3 or 4 times between 600-800 rpm then settles down at about 700.
          • 7pilot
            • 475
            The ICV may need a cleaning and some lubricant e.g., Triflow.
            m
