e30 coolant system
  • okookkos
    • Jan 2017
    • 8
    e30 coolant system
    i have noticed my coolant expansion tank has been dry for awhile. (probably should have done something earlier). but it hasnt been overheating. should i completely flush the system or just top off the tank with 50/50?
  • dereliiict
    • Jun 2013
    • 748
    And this is your one and only post?
    Dude...
    Derek-
    • M_3_X
      • Jul 2016
      • 162
      I'd say just top it off, see how much was missing and monitor it. But more importantly, why did it go that low? You might have other issues...Also, the low coolant level sensor should be replaced if it didn't give you a warning.
      "If everything seems under control, you're just not going fast enough"
      -Mario Andretti.
      ___________________
      River City Bimmers BMW CCA
      2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
      2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
      1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
      • okookkos
        • Jan 2017
        • 8
        thanks for a non smart ass reply. im gonna look into it. i havent noticed any leaks or anything so i will top it off and monitor it. PS still getting used to these forum things...
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5616
          Good luck getting used to this one
          Also, just a tip.. assuming you dont live Siberia dont waste your money putting coolant in it if youre not sure if its leaking or not. just add some distilled water, make sure its not leaking, drain that shit out and add whatever floats your boat.
          • rcsoundn1
            • Nov 2012
            • 3361
            Add coolant, it's not that expensive, and has a higher boiling point, and lower freezing point. Don't use water! Buy some 100% antifreeze, mix 50/50 with water and be safe
