Hello, im from Sweden and ive got a problem with my m20b25, car has been standing still for like 6 months and after that time i have changed alot of parts, headgasket, timing belts, waterpump, spark plugs,camshaft seal, fuel filter. Battery disconnected when doing all this ofc.
It runs good on idle with the IVC connected, but when you rev the engine it goes up and down in revs..
If i inplug IVC connector the engine revs normally.
Engine runs rich on fuel and i belivie its alot.. when i rev it standing still, it works fine without the IVC connected but when i drive it for example first gear and gas pedal to the bottom it starts to cough/cut..
i have tested with another IVC (still the same) I have cleaned mine properly and it worked before.. so i dont think IVC is the problem here. I also tried with another TPS, still the same problem unless this tps is bad also?. i cleaned the afm and throttlebody.
Anyone has an idea? Before i did all this the timing on the engine was off with 1-2 clicks.. And the car was running alright but it didnt have any power unless you were at high rpm. The camshaft is not the best condition either.
I checked the spark plugs and they are black, so it gets to mutch fuel?
