Story:
New:
I jumped the relay the fuel pump relay and the car runs. I hooked my listening device up to listen to the fuel injectors and they are clicking. fuel pump is pumping but there is no gas coming our of the return line so that concerns me.
I reconnected everything and unhooked the fuel pump's power and hoooked up a tester light and the light came on when cranking. so the relay is good.
so im at a loss. im not sure if my fuel pump is going bad or if my fuel pressure regulator is bad
or if there isnt enough power getting to the fuel pump
I dont know why when i jump the fuel pump relay it works and when the relay is in doesnt seem to be getting enough power.
Im going to buy another pump and let everyone know
Old:
About a week ago I was driving my 89 IS and I got a check engine light and a weird idle. Then I shut the car off thinking it was over heating (It wasn't), started it back up again and it was fine. Then 10 mins later I get where I'm going and I shut it off. I then return to my car and it wont start.
Fast forward to now, I change the CPS and checked the ohms on both the old one and the new one. (the new one was within 560-590 Ohms). I checked the fuel pump relay, relay clicked at 12V, and I still put in another relay that I had laying around in its place. I jumped the pins in the fuel relay to check if it was the pump and it started to pump no prob. It ran when the relay is jumped but when the relay was normal it didn't pump when cranking.
I'm at a loss here, but I haven't checked the ohms at the ecu (very last option, I hope I don't need to do that)
What else can it be!??
New:
Old:
![Shifty](https://www.r3vlimited.com/board/core/images/smilies/shifty.gif)
