no oil to cylinder head
  • low808
    • Nov 2013
    • 661
    Just replaced my cylinder head from a 200 to a 885. Just got everything back together but now no oil.
  • e30sh
    • Apr 2015
    • 618
    Did you get an 885 head off a SETA? Some of those have the 4 bearing cam and need extra holes drilled to get all the cam journals and rockers to oil.
    • low808
      • Nov 2013
      • 661
      I got it from a e34. I took the timing belt off and slid #1 rocker to the side and turned the oil pulley. Oil was coming out. Maybe I will try starting it again. When I put it back together.
      • low808
        • Nov 2013
        • 661
        So when I pulled the tb I remember it was one tooth off and was making a kocking noise. Intermediate to cam side of the belt was loose. Fixed it an sounds way better. Now it seems to have oil into the head also.
