Coolant hose set question
  • samaroo
    • Dec 2016
    • 20
    I have an 87 325e and pulled the motor and did a complete rebuild on the block and through the 885 head on for plans of boost. I like to consider myself mechanically inclined but strictly with the mechanical part. While I still have the motor out, I want to get a coolant hose set. ECS tuning has a kit for $150 but it looks like it has more hoses than what I originally had in the car. Any recommendations would be awesome and if there is a dummy proof diagram of what hoses go where, that'd be sick. Same goes for a vacuum line set, but I can do that when the motor goes in the car so i'm not as worried. I don't have a garage and pay $130 a month for a storage unit so the sooner I can get this car running, the better. Thanks again. Feel free to make fun of me for only knowing the mechanical part of being a shadetree on the side mechanic.
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5611
    It literally took me 5 seconds to search and find this.
    • AutobahNZ
      • Apr 2017
      • 11
      samaroo the best website that will help you with finding part numbers and diagrams is probably http://www.realoem.com/bmw/enUS/select
      If you put in the last 7 digits of your VIN, you can get plenty of diagrams and part numbers for the items you need.
      After that it's pretty easy to use ECS, Pelican Parts, Turner, Amazon, or whatever once you have what you are looking for.
      Happy hunting!
      EDIT: also a Bentley manual for an E30 will help a lot for any kind of mechanical work. As to the vacuum lines on eta cars (like the 325e) there can be significantly more than later 325i motronic cars, so if you get stuck you can always post up a picture of what you have.
      • samaroo
        • Dec 2016
        • 20
        Thanks yall! I really appreciate it!
