Idle
  • l0gistaja
    • Oct 2017
    • 16
    Idle
    Hello!
    I recently bought my first ever E30 and I just wanna clarify something about the engine. Is it normal for an M20B20 to idle like in the beginning of this video https://www.youtube.com/watch?v=phf0...ature=youtu.be
    The guy I bought my car from said it had an M20B25 but when I got home I noticed that the code on the block was 206KA (b20). The way it idles seemed weird to me and so I went online to check out some examples and in most videos the idle seems a lot smoother unlike in the video I linked.
    So this got me thinking if maybe the engine has been modified in some way. So yeah.. is this idle normal for a stock M20B20 engine?
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5599
    It sounds like a vacuum leak. Or the valves could be really out of spec.
    I'd check valve/rocker arm clearances, because that's just a regular maintenance procedure for these engines, then preform a smoke test, or a ghetto break cleaner test to see if there are any vacuum leaks.
    • M_3_X
      • Jul 2016
      • 162
      Idle
      Well the car in the video idles like that because of hot cam
      "If everything seems under control, you're just not going fast enough"
      -Mario Andretti.
      ___________________
      River City Bimmers BMW CCA
      2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
      2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
      1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
