Hey guys so i have a little problem with my car...
so about 10 days ago i noticed sometimes my car would start cutting out while driving, but only for a split second at any rpm. like i'd be driving and all of a sudden the car would cut out for a split second and shake back and forth.
and it's been getting worse, now every morning i start up the car it'll do this cutting out only until its warm about about an hour of driving and i'll drive the rest of the day with maybe 1 or 2 cut outs...
what could be causing this problem?
and to save some time i made a list of parts i have replaced in the past year just because i wanted to do some preventative maintenance...
This car's engine management system is a Motronic 1.0
The whole ignition system- plugs, wires, coil, distributor and cap.
DME temp sensor.
brand VDO ICV.
throttle position sensor.
O2 sensor along with a whole new exhaust and cat.
cold start valve.
alternator.
Thermo time switch (to activate cold start valve).
i did not replace or test the Crank Position Sensor, there are in total 3 in the Motronic system of this car one is in the front of the car on top of the flywheel but it is only for diagnostic testing and not connected to the DME and it's wire goes right to the diagnostic plug, so it doesn't matter
The 2 others are in the bell housing, from what I've read one counts the teeth on the flywheel (position of the crank) and the other is a reference for the fuel injector pulses.
i was thinking maybe one of those 2 could be starting to break?
I've also checked the fuel pressure at the rail while i was driving and everything seems to be good, no sudden drops in fuel pressure.
also when i got to crank the car over for the first time it almost died but quickly shots up and starts to idle normally except for the rpms going up and down ever so slightly?
DME temp sensor.
brand VDO ICV.
cold start valve.
alternator.
