M20 Flywheel felt ring # 11211744601 NLA , Question
  • cdeason7
    • May 2016
    • 38
    In the process of rebuilding the M20, tried to order the flywheel felt ring seal and it is now NLA. Is this part necessary ? If so, what did you use ? Thanks
  • Eskie
    • Dec 2014
    • 162
    Same here. I just put it together without it, no problems in 20k miles. If I had to guess what it’s for it’s probably either puts slight preload on the input shaft or it held the grease in for the old style open pilot bearing.
    • noid
      • 1537
      Its NLA because the superseding part is now a sealed bearing; the sealed pilot bearing is all you need.
      Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
      Your resource to tools and tips: www.rtstools.com
      • cdeason7
        • May 2016
        • 38
        thanks for the replies
