So I need to install a new fan plug, I pulled one that has plenty of all three wires attached to it, but I can't find the grounding wire on either side of the radiator, where does it lead? How would I go about finding it? If it's not there, and the ground on the plug isn't enough wire to reach, what's next? In addition, you will see in the third picture a white circle and a yellow circle. (Drivers side of the engine bay in front of the airbox/coolant expansion tank) The white circle indicates a frayed wire of unknown origin or use, and the yellow circle indicates a cut brown wire, so if someone could attempt to properly identify these, it would be much appreciated.
Sent from my SM-G960U using Tapatalk
