Alright so I’m planning on doing a 2.7I build on my 1988 325 (Seta) over this coming winter. However as I looked at more and more pages explaining the process it became more and more confusing to me as to what I should do to accomplish this. Here is what I think I need to do in order to get it done
Current thoughts
1. New camshaft and dual valve springs in my current head (I’ve heard a lot of stuff about whether or not I can use this head without drilling so please clear this up although since they are 885s it only makes sense to me that I can)
2. The entire intake system from an I car
3. New ecu (id like to do a mega squirt as I want to turbo it after this)
4. Cluster with 7K tachometer
5. LSD (I’ve heard both 3.73 and 4.1 are good if anyone has tried both I’d appreciate an opinion on this)
6. I’ve heard some people say a new exhaust is a must but as I said I’d like to turbo later so I don’t wanna buy/make headers now then get rid of them in a year or so (I already have a magnaflow catback on too)
7. Bigger fuel injectors and regulator (I know 19lbs works for NA but again turbo)
Question Time
1. If I go bigger with the injectors will I need a stronger pump too?
2. I know for the normal eta replacing the alternator to the 90 A one is a good idea but for us seta guys do we already have one of them and same with the ignition system?
3. Would getting one of those oil cooler housings that goes up in front of the filters be a good idea or is there not much needed for cooling until boosted? And is there another way to add in an oil cooler as I don’t really want cooling lines right next to a hot manifold
4. Due to doing a mega squirt ecu what in this process changes is anything easier or harder? Should I wait on this and just do the 173 motronic 1.3 conversion?
5. Would anyone recommend going with a hotter cam that will work great both while NA and boosted or should I just buy a relatively cheap I cam?
Side Note
Yes, I know about the whole www.strictlyeta.net/technical/328i_1.html page so I’d appreciate it if you didn’t just link me there it’s a great resource but I just want to be 100% sure about everything I’m buying before I spend the money on it
Thank you to anyone who responds to this post and helps me through this build
Also I’ll be making a thread on this once I’m clear on everything as I’ve noticed almost nobody’s done that which is part of why I think there’s so much misinformation and confusion on the topic
Current thoughts
Question Time
Side Note
