Stubborn misfire
  • angelfire
    • Nov 2018
    • 32
    Stubborn misfire
    I recently replaced all the vacuum lines and gaskets on the intake side of my m20 along with adjusting the valves for the 3rd time (they are still quite noisy. I adjusted at the eccentric and the cam). It’s got a pretty good miss when it’s cold but as it warms up it starts to go away but not completely. Pulling the spark plug wires changes the idle on all 6 cylinders. I don’t have any vacuum leaks (I did a smoke test) and I’m starting to get stumped. I’m down 20 psi on compression cylinders 5-6. Could that cause this? It’s only at idle. Also if you rev it and let off the throttle it stumbles and acts like it’s gonna die but then catches itself. It’s got some cheap plug wires on it too which I want to replace along with the cap and rotor. Anyone have any tips?
  • AndrewBird
    The Mad Scientist
    • 11898
    Plug wires, cap and rotor are definitely a good place to start. You could always try cleaning the contacts on them first to see if it helps.
    How is your fuel mileage? Could be a bad temp sensor causing the engine to run rich.
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5586
      Is it a random miss or a dead cylinder?
      While it's misfiring, pull each wire and see if you can isolate the miss to a specific cylinder.
      IF you feel the engine hesitate when you pull each of the six wires, then you have a random miss and that's most likely a vac leak. If you have one dead cylinder, check the injector, plug, wire, cap and compression
      Also, about the ticking, remember that m20 injectors click loud as shit. Most people think their valve adjustment is done wrong, but in reality, they're just hearing the injectors.
      • angelfire
        • Nov 2018
        • 32
        I don’t drive the car much but when I do, the highest I have seen is about 16 mpg according to the on board computer. That’s city driving. When I pull the spark plug wires off, all cylinders make the engine run rougher. So I’m guessing it’s a random miss. I smoke tested the vacuum lines but I will try again. Brake pedal feels really hard but that could be me not used to an e30. I just put new spark plugs in it and I pulled them and they seem ok. I think it’s time for a cap, rotor, plug wires, and sensors (CP, coolant temp, and o2. Some are Saying to replace the ICV but mine tested OK with the ohmmeter. I’m hesitant to replace it because it’s so expensive. Could it be my AFM? I would like to replace that with a Miller maf in the future
        • DaveH91e30
          • Sep 2016
          • 41
          Try cleaning your CPS, the one mounted close to the A/C compressor. I had a similar issue with misfire when cold start and went away after a couple of minutes. It would return if the car is driven and the ambient temp was below 35f and "Cooled" the sensor down due to airflow.
          I ended up replacing many parts hunting down the misfire.... turned out to be a dirty (oil and grime covered) CPS...
          • ADEN
            • 620
            Tps did to me what u described
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5586
              A TPS will not cause a misfire.
              ICVs rarely go bad, but I would definitely clean it and make sure the vane moves freely.
              Also, an O2 sensor will cause a rough idle, if not working correctly. You can buy a ford one and splice it to the old connector. Should cost around 25 bucks
