rebuilt head, 272, on used M20b25 lower end ?
  • Von Soman
    • Dec 2018
    • 48
    I purchased a low millage engine (88K) in unknown condition a few months back. I was told it is in great shape but I can not confirm that yet. Lets assume it has good compression. I am getting ready to install it and plan on doing the timing belt, water pump. oil pan gasket and rear main seal before the install.
    I would like to make it a little more exciting in the performance category and thought a valve job, 272 cam, dual valve springs, lighten flywheel, chip and headers would be great.
    Is there any potential problems using a rebuilt head with a cam change on a older bottom end?
    Thanks in advance.
  • the_eskimo_wonder
    • Sep 2017
    • 182
    Give it a leakdown test to confirm its good and if it is then nothing wrong with the upgrades you’re talking about on a used bottom end. Head rebuild is always a good idea.
    Build Thread
    • Von Soman
      • Dec 2018
      • 48
      Thanks for your reply
      • Von Soman
        • Dec 2018
        • 48
        Any suggestions on a machine shop in the Inland empire that knows the M20?
        • Andre3127
          • Dec 2017
          • 291
          You already have dual valve springs. A looser bottom end is usually not a bad thing when searching for power, but as always check your oil filters.
          Budget E30 Parts - Used and Reconditioned parts for your BMW
          • mr2peak
            • 2388
            Bimmerheads in North LA is the go-to for M20 stuff
            Drive it hard. Maintain it well.
            A Topless Memorandum
