Fuel Pump Relay, part number and where to purchase?
  • IS300E30
    • Apr 2009
    • 408
    So, I bought this relay (part number 61311373585) as it seems to match up with the current fuel pump relay that is installed on the car:
    https://www.ecstuning.com/b-bosch-pa...BoCwuoQAvD_BwE
    What I received however was part number 61-36-1-378-238 which is an orange relay and I believe is the O2 Sensor relay
    I started doing a little bit more searching, and I stumbled on to here:
    https://www.fcpeuro.com/products/bmw...-61368373700oe
    Which says "1987 BMW 325i
    Originally produced as a 4 prong relay, it has been superceded to a 5 prong relay."
    Now, I am lost on what the correct relay I should get. Currently the fuel pump relay is a 4 prong relay on my car.
  • e30austin
    • 15382
    12 63 1 277 245 - this is what my catalogue lists for a 1988 BMW 325is, which I do not agree with. The pins are in the wrong locations and RealOEM lists it being for a euro spec E30.
    • IS300E30
      • Apr 2009
      • 408
      e30austin, thank you for the quick reply but when I pulled that part number up it looks a lot different than mine. Might be that mine is an 87 and has 2 fuel pumps? Not sure.
      • e30austin
        • 15382
        Very interesting. I even pulled up RealOEM and they are also giving me the 5 pin, main DME relay, for the fuel pump...something weird is going on.
        The part number ending in 585 is the correct unit, for the fuel pump relay.
        • IS300E30
          • Apr 2009
          • 408
          Maybe the green one? Per the description, the 5th prong goes into a blank slot so it is not being used anyways. Does this seem right?:
          OEM and Genuine parts at the best prices. BMW Mini Relay (5-Pin) (Light Green) (Multi-Purpose) 61368373700 guaranteed fit and fast shipping
