Sometimes the car will just keep cranking and cranking but won't start. I can go back later after a few hours and it will maybe just start right up. The second issue is when it does start after you rev it it has a hard time holding an idle and just dies. If you rev it go lets say 3-4k when it comes down it will just die. I know that sounds like a vac leak but I have checked every source I can think if for a leak.
I don't have new wires or a dis cap but the rotor is new spark plugs are new i've tried a different DME. I've swapped a differ cps out as well. New fuel pump walbro 255 and a new fuel filter new lines ect as well. Had a spare icv and cleaned both still same issue what am I missing....
