help me lease fuel lines
  • franco90
    • 3185
    ok gurus here is the problem I have I turn car on today and I had hood open and i seen a leak it smell like fuel the hose had a leak here is pics
    question how hard is to replace hose
    how much will a new hose cost
    any one has part number
    thanks
    Franco
    I've always been proud of being a Marine.
    I won't hesitate to defend the Corps
    "Supersquad"
    ‎"Prostitutes are a sub-category of Amusement Parks"-
  • E30 Reaktionär
    Site Manager
    • 14451
    I'd just run down to your local auto zone or what ever you have. And grab a piece long enuff for your needs (they only sell it in feet) Make sure you get EFI hose and get some new clambs too while your there. I think it is 3-4 bucks per foot but i can't recall.
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
    • franco90
      • 3185
      where is the other end of the hose how hard is to replace both hoses thanks
      "Supersquad"
      • FredK
        • 14759
        The other end of the hose is on the inside of the driver's side frame rail, on the underside of the car. Be careful not to mix up the hoses when you replace them, so replace them one at a time.
        Use 5/16" fuel injection hose. Just ask for it at your local auto parts store. Get around 5 feet.
        It's a really easy job.
        Before you do the job, depressurize the fuel system by pulling the fuel pump fuse and cranking the car until it dies.
        • Mike325
          • Mar 2006
          • 3685
          Yep, what he said. Be careful of fuel spilling out. Get a nice catch pan under your car. Also, take a razor blade and cut the hoses off at the connection. Just a slice along the connection. They will be stuck on and pulling them actually creates a suction and that makes it harder.
          Good luck. You will smell after :D for a while.
          Originally posted by Kershaw
          • franco90
            • 3185
            ok thanks guys I guess i will have to lift car of the ground to do this or can i remove driver front side tire ? which is easier .
            I will do this on saturday I guess also i will take pictures thanks again guys
            "Supersquad"
            • FredK
              • 14759
              Lift the car off the ground. You don't need to remove the wheels. Be careful! Make sure your car is on jackstands or ramps, and chock the rear tires.
              • euroshark
                • Apr 2006
                • 3491
                I'm pretty sure you should be able to reach without lifting the car... I didn't lift mine when I did the fuel lines. Definitely use a razor to slice them off, like Mike said, its TONS easier.
                • franco90
                  • 3185
                  got the hoses off tonight I lifted the car to get under it .
                  man what a pain i used muslce power to do it any way when to auto zone could not find the hose i will try dealer tomorrow
                  "Supersquad"
                  • mrsleeve
                    • Mar 2005
                    • 16386
                    Dude try a different parts store, 5/16 high pressure fuel hose is so common that they might just be out. Try a NAPA or Car quest, Advance Auto or another Auto Zone. anyone of them will have it. Wow I cant belive I just told someone to go to all those places.
                    Originally posted by Fusion
                    William Pitt-
                    • franco90
                      • 3185
                      thank guys I really appreciated all the help i mean it
                      "Supersquad"
                      • franco90
                        • 3185
                        I replace both hoses tonight man it was cold but you know we all love our bimmers. it really help removing intake
                        "Supersquad"
                        • franco90
                          • 3185
                          thats pics of old hose remove
                          "Supersquad"
                          • mrsleeve
                            • Mar 2005
                            • 16386
                            Tell me about it, I am swapping a head in my drive way (I cant get this car in the garage due to the other 1 an all the shit in it) Its cold out there.
                            William Pitt-
                            • franco90
                              • 3185
                              dude beer and newports will help and gloves
                              "Supersquad"
