When pulling out the oil dipstick while the car is running, the idle change erratically. Normal or not?
Quick Dumb question! Normal or not?
I have a followup question about this. Doesn't the valve cover breather hose attach to the TB BEFORE the throttle plate? Therefore this would not really create a vacuum leak?
I've been told that if I open the oil filler cap OR if I pull the dipstick the idle should change - since mine does not I'm wondering what's going on... Also perhaps I have screwed up and switched the valve cover breather hose and the ICV hose??? Although I don't think that's possible because of the orientation of the fittings on the TB.....
Is the valve cover breather hose attachment on the TB before or after the throttle plate???
Originally posted by winstontj View PostI have a followup question about this. Doesn't the valve cover breather hose attach to the TB BEFORE the throttle plate? Therefore this would not really create a vacuum leak?
Is the valve cover breather hose attachment on the TB before or after the throttle plate???Adam Fogg- '88 M3
Common sense- It's the new 'gifted'
