I have a 90' IS and I was wondering since so many other things are different on the airbag cars, is the shifting arm different in the 90+ than in the earlier cars. The reason I ask is because the shifting arms that I have seen on most e30's are in a straight line from the rear bearing to the front bearing for the arm. The shifting arm on my car goes straight from the rear bearing to where the shift lever sits and then after the housing for the lever, it goes to the right at about a 45 degree angle.
could this be just how the shifting arms were on the airbag+ cars? or might I be dealing with a bigger problem like a bent shifting arm?
I think bending that arm would be fairly hard to do but it probably isn't impossible.
let me know
thanks
E30Fiend
let me know
thanks
E30Fiend
R.I.P 07/01/09 - 04/23/10 :(
