SeaFoam ??
  • -Javier-
    • May 2007
    • 382
    SeaFoam ??
    whats the best way to introduce seafoam into the engine beside from a vacuum line so it can clean the bad stuff inside the chambers?
  • cabin
    • Dec 2006
    • 552
    Whats wrong with using a vacuum line? It works just fine that way.
    If you don't want to do that, you can put some in the crank case or pour some in with the fuel, or both.
    -Justin
    Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
      • 37834
      I just did this to mine a couple weeks ago. Took off the IVC line and did it through there.
      I did half the can in there and half in the oil. My engine liked it.
      Grover Beach, California
      BimmerHeads.com
      • AlarmedBread
        • Sep 2006
        • 1510
        I'm considering doing this soon too, mainly for oil gunk buildup. I'm afraid that if I do, there will be much leakage. Maybe I should leave well enough alone since the chambers are fairly clean.
