E to I swap done now it wont start
  • maniacmatt
    • Feb 2007
    • 483
    I just finished swapping a '90 325i engine into my '84 325e and it will not start.
    The engine does not turn over I hear what I think is the solenoid clicking when I turn the key but the engine does not turn. The starter should be good as it is off my E engine which started and drove immediately before the swap. I am also quite confident that the connections to the starter are correct as I looked at my dads '88 325ix and they are the same. I made the adapter harness exactly as described by Mr325 (Mr Deagle). The only thing I can possibly think of is the fact that I dont have that little grounding block on the strut tower found on the late model cars so I used one of the old mounting points for the coolant reservoir but I ground off all the paint and my electric fan which uses the same ground works.
    Anyone have any Idea what is wrong. I can't think of anything and this car is wearing my patience and sanity very thin.
    Please Help!
  • maniacmatt
    • Feb 2007
    • 483
    Oh and before someone says it the battery is charged.
    • JoeMadoo
      • 936
      Umm make sure you have the fat ground wire on the engine mount hooked up to the frame on the drivers side.
      If your 325e was an automatic you have to jumper the starter relay.
      What else....
      The 3 pin connection in your glove box (c104 i think), make the connection from the green/red wire to the (+) terminal on the coil to bypass the code function on the OBC if you have one. If you haven't already.
      Just a few things.
      '86 E30
      '05 E53 X5
      '72 Firebird
      '10 Prius
      '03 Tundra
      • maniacmatt
        • Feb 2007
        • 483
        Thanks Ill check all of that out today and let you know
        • Mr Deagle
          • 1121
          If it was/is an auto, you will have to jump 2 wires to get the engine to start (the wires are green +yellow stripe at the shifter area)
          Most likely that is the problem
          C104 (3 pin in glovebox) has nothing to do with engine starting
          edit: the "clicking" you hear is probably the relays clicking on, not the starter
          • maniacmatt
            • Feb 2007
            • 483
            I think I figured it out.
            The car was never an auto so that isn't the problem. But I got under there with the voltmeter today and I have power to terminal 50 on the starter solenoid when the key is turned but no power to the braided wire from the solenoid to the motor. So I am assuming that the starter solenoid is the problem and am going to try and pick another one up tomorrow
            • JoeMadoo
              • 936
              If he has a manual harness it dosent matter if he jumpers the wires by the shifter because they wont go anywhere, that wire will just be hanging in the glove box. He needs to jumper it at the relay under the steering wheel.
              And the C104 is required to start it because if it's not plugged in or bypassed there wont be power to the main relay.
              But it dosen't matter.
              '86 E30
              '05 E53 X5
              '72 Firebird
              '10 Prius
              '03 Tundra
              • Mr Deagle
                • 1121
                Im confused
                C104 = 3 pin in glovebox???? or circular connector on firewall?
                • JoeMadoo
                  • 936
                  C104 is 3 pin in the glove box. the fat green/red wire on there need to be connected to the coil or atleast something that has power in the ON/Start Position because the other end of that wire goes to the main relay. if its not connected, the car wont start, it will turn over though.
                  '86 E30
                  '05 E53 X5
                  '72 Firebird
                  '10 Prius
                  '03 Tundra
                  • maniacmatt
                    • Feb 2007
                    • 483
                    That not true JoeMadoo. The only connection I have to my c104 is the wire from pin #9 on the c101 connector for the tach.
                    And for the record it was the starter solenoid I have no idea how but it was. I drove it today and other than a little surge at idle once it warms up everything is great :)
                    • JoeMadoo
                      • 936
                      Oh ok, glad you got it workin. I was told it was a must, but i never tried it without.
                      '86 E30
                      '05 E53 X5
                      '72 Firebird
                      '10 Prius
                      '03 Tundra
                      • James Crivellone
                        Head Janitor
                        • 6297
                        87i harness's require that C104 power feed, as well as ETA's of course., as well as most of the Motronic 1.1 M30 Harness's.
                        88+ never required it, as its wired differently overall. All you need out of C104 is Tach and MPG feeds.
                        • Mr Deagle
                          • 1121
                          In my 85 eta that i had, it didnt require any power to c104
                            • 37825
                            Yay e to i swaps.
                            Classic BMW Specialists
                            Santa Clarita, CA
                            www.BimmerHeads.com
                            • maniacmatt
                              • Feb 2007
                              • 483
                              Indeed. Now I just have to get it broken in and take some pictures.
                              Thanks to everyone who helped out along the way
