took my e30 to the shop this mornin cause the engine was running and sounding like crap and they said it sounds like a cylinder isnt firing.
What do you guys suggest I do? Any common causes for a cylinder all of a sudden not firing anymore?
Im gonna try and take a look at the spark plugs this afternoon. Pull em out one buy one and see if there is any build up on the ends and seeing if they fire. I was told if they aren't firing the ends should be black and prolly will have some gas on em. If they are firing fine the ends should a brownish color correct?
Any other suggestions? Distributor cap/rotor maybe? I know two of my cams are pretty worn, could this be an issue?
TIA
Ryan
TIA
Ryan
