Original problem:
Car overheated while idling. Aux fan would not come on. Radiator only got hot on the drivers side. Car had heat inside.
This is what I have done:
- NEW Thermostat (heated to make sure it works)
- NEW Water Pump (and tbelt and tensioner while I was there)
- NEW Radiator (mine was chock full of rusty goodness)
- Jumped & checked the aux fan - the fan only works on high - my resistor is bad - have not replaced it yet (it's a Magna).
- Jumped the aux fan (for now) on high speed so that it is always on
- Flushed and filled
- Bled the system on an even surface
Current status of my overheating:
After flushing the rad (not the block... forgot to do that), and bleeding the system using the bleeder screw, with the aux fan always on high - car still heats up to 3/4. Does not go above that, but does not go to 1/2 either. When I open the bleeder screw and rev the car to 1500~ RPM the heat goes down to almost halfway between 1/2 and 3/4... but never lower. Car still has heat inside of the car... even better heat now that the rad has been replaced.
Note: After replacing the rad, it still only gets hot on the drivers side.
My theories:
I'm thinking of trying to flush the system again, this time flushing the engine block as well. Filling, and then trying to bleed the system on an incline instead of on a flat surface like I have been doing. After a lot of post digging I read that this could help bleed the system better.
Questions:
- When the car is idling at normal speed (800~900RPM) should there be coolant coming out of the bleeder screw?
- Should all of the radiator get hot when the car is hot?
- Should I check the lower hose on the rad (pass side) and should that hose be hot or cold?
- Visual inspection of the lower hose seemed like it was in good shape... but how can I really tell?
- Does anyone have a good diagram of the coolant system flow for 88+ m20 engines (coolant tank on drivers side)? The Bentley only has the older system (pre-88) and it confuses me when I look at it.
Thanks for all your help!! :)
My theories:
Questions:
