There is a 325i at a junkyard near me, i have a 325e so i would like to pull the head from the 325i so i can get its camshaft and valve springs. The head bolts are torx though and i wonder what i should use to get them out? i went to 3 hardware stores and none of them had a socket that goes over the torx head of the head bolts?
Need help quick! head bolt torx?
97 tacoma 5 spd 4 cylinder
2001 330ci 5 speed
83 733i 5 speed, (FS)Tags: None -
Just did some searching, who sells inverted torx sockets? i need some really bad so i can grab my parts before they crush the car.97 tacoma 5 spd 4 cylinder
2001 330ci 5 speed
83 733i 5 speed, (FS) -
Hi. I use a good solid 10m or 11m (cant remember which now, but i think 11mm), 6 sided hex socket. I probably wouldnt recommend using that to torque headbolts, but for removal it's fine. Same on transmission. for those smaller ones use 8mm 6 sided hex socket.
:roll:Comment
last resort.
If you strip one of these bad boys, you are in a world of hurtJoe Funk -- Portland Oregon
That Guy.
03 X5. 3 liter obviously.Comment
Not really, i just need to gank the camshaft and valve springs off a junkyard car.
Sears FTW, just picked up a set of inverted torx, sorry i about had a noob atack, just the first 2 hardware stores i went to acted like the inverted torx didn't exist.97 tacoma 5 spd 4 cylinder
2001 330ci 5 speed
83 733i 5 speed, (FS)Comment
