91 vert automatic m20. get up this morning no start.
get back this afternoon, go through my system diagnostic.....
narrow it down to the coil. here are the facts:
- coil is only gettin 6 - 8 volts on the 15+ positive side
- if i feed it 12 volts car starts
- if i disconnect the ecm 15+ side shows 12 volts
- ignition switch green wire has 12 volts at switch but if i disconnect c200 connector ( which is the one the switch harness connects to ), i get no continuity from c200 to the positive coil wire. which according to the etm scematics , ( which are so innaccurate )there should be continuity.
- i disconnected my remote start, which is in the path of the green wire and all symtoms remain the same.
any help would be greatly appreciated.
