Is my engine block clean enough to mount the head? (PICS)
  • amdspitfire
    • Mar 2006
    • 254
    Been scrubbing like crazy and using a wire brush on the block to clean it up. It still doesn't seem perfect.
    WATERPUMP SURROUND:
    Does all that need to come off? What's the best way?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    looks ok, green scotch brite is your friend....
    • dmoney(AB)
      • 1372
      try a gasket scraper or razor blade, thats what I use at work, lots of brake cleans too.
      mtech1/2jzgte/r154/275tire
      function>form
      • Jordan
        • 12916
        No no no, do NOT use scotchbrite. For shits sake people. That abrasive will find its way into your cylinder bores, and get trapped in the piston rings. Using abrasives to clean a sealing surface is always a bad idea.
        Use a razor blade (in a solid holder) to scrape the rest of the crap off. If you have compressed air and a die grinder then use a 3M Roloc bristle disc, they are made for this.
        https://mtechniqueabs.com/
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          stupid me, i meant the brown discs, i pulled a brainfart. I need to stop posting while writing up invoices for customers at work. Sorry for the stupid. I meant 3M and scotchbrite came out.
          • dark89e30
            • 263
            No, it's not clean enough because you have metal shavings inside every orifice on your block!!
            • thereisnoyun
              • Feb 2007
              • 2301
              cleaning surface for gasket
              use razor like everyone said... its the best way... I wouldnt use a wire brush for gaskets surfaces... its kind of too rough...
              • amdspitfire
                • Mar 2006
                • 254
                what should I use to clean the surface/holes? Compressed air then a wipe with alcohol?
                • SpecM
                  • Oct 2005
                  • 4531
                  -I'd wipe with some brake-clean/parts cleaner, but I guess alcohol will work.
                  1989 cirrisblau-metallic 325i
